I have such error when i export ansys file: 'attribute array2d index (2,1) is not valid', do You know what it is?
Hi Jakub,
Please let us know the following:
1) Are you in ANSYS profile when you are exporting?
2) Is the entire model is modelled in HyperMesh?
3) What is the version of HyperWorks were you using when you export to ANSYS format?
Hi Jakub, Please let us know the following: 1) Are you in ANSYS profile when you are exporting? 2) Is the entire model is modelled in HyperMesh? 3) What is the version of HyperWorks were you using when you export to ANSYS format?
I build a model with Nastran profile then export it into Ansys via 'Export Solver Deck'. It works without any warning/error.
I'm working with release 13.0 with all update.
