Hi, I have model from ansys classic, works on, when I make cdb file to edit it in hypermesh all is ok. I import file from cdb, to hypermesh, and when i want to export it to second cdb file the message appears that there are vaild elements (only contact elements), do i want to save them. After that when I import file to ansys it doesnt work. In component table all element type seems to be correct. Do you know how to fix it?
