Hi i build midsurf with different geometry thicknesses. How I Can automatically make property for thickness? I use HM 14 where there is now Midsurf thickness in utility - geom/mesh.
check the following topic:
https://www.youtube.com/embed/8aHrbUCqi4E?feature=oembed
that is exactly what I wrote. In hm14 there is no midsurf thickness option i utility - geom/mesh....
There was a misunderstanding- you probably meant no instead of now.
To access the Midsurface Thickness Map, from the menu bar, click Mesh > Assign > Midsurface Thickness. The tool displays in a new tab in the tab area.
Also try Mesh>assign>midmesh thickness.
thanks!
