How to assign 3d flex to flex contact like in recurdyn (not point to deformable surface) plz kindly provide me a solution
Hi jillukevin
Flex to Flex contact is a limitation in MV/MS. At the current version this is not supported.
As a workaround define a deformable surface on the surface of the flexible body and create a “point to deformable surface”.
you can refer to the tutorial MV-1028: Modeling Point-to-Deformable-Surface (PTdSF) Higher-Pair Constraint to define point to deformable surface
Thanks u so much for the reply sir . Giving ptdsf joint becomes tedious when I want to define contact between flex surface to flex surface even though i can select the interface nodes of the flex body1 as a point and deformable surface of flex body2 the solver gives me a error that parametric value of deformable surface went out of range value =.5015, how to increase this parametric value of this deformable surface beyond this range. thank u
Hi jillukevin Flex to Flex contact is a limitation in MV/MS. At the current version this is not supported. As a workaround define a deformable surface on the surface of the flexible body and create a “point to deformable surface”. you can refer to the tutorial MV-1028: Modeling Point-to-Deformable-Surface (PTdSF) Higher-Pair Constraint to define point to deformable surface
where to find "MV-1028: Modeling Point-to-Deformable-Surface (PTdSF) Higher-Pair Constraint" ?
Hi Nicolas,
Please find the tutorial here:
https://help.altair.com/hwsolvers/ms/topics/tutorials/mv/tut_mv_1028_t.htm?zoom_highlight=MV-1028
Hope this helps!
Adam Reid
This is original a 10y old comment. Both MotioView/MotionSolve and InspireMotion supports Flex-Flex contact via the standard contact setup.
/Erik
