hi
i have given constant velocity for the joint and have given contacts between the roller and floor .so for this model when its goes down the slope it over rides the initial condition that i have given for the joint, that is it rolls freely as in a free fall .Is there anyway so that i can make the system run with constant velocity even on a slope with down gradient
thank you
