Default unit for Hyperview in milimeter (mm), right?
Can I change it to meter,(m)?
*I want to do post-processing from AcuSolve result and default unit for AcuSolve is in meter,(m).
Thank you
Hyperview (and Hypermesh too) is 'unitless' system. The unit coherence of input data (and results) is user's responsibility.
As Q.NGUYEN-DAI said, there is no default unit system for HyperView. it is user's concern to maintain unit consistency. If you have given in Meters for your model, then HyperView will display results for the same unit(s).
Here's Unit consistent table (found in Internet).
HTH,
