I want to select nodes from from the first node to 20th node.is there a short way of selecting the nodes other than picking them one by one? thanks. See Sketch below.
Hi Venkat,
In HyperMesh many option are available, you choose nodes by bypath as below
In the new interface you hold down the Alt key while selecting nodes to select by path.For elements holding the Alt key will select faces.
