HI Team,
Please provide API to find elements connected to node in Hyperview
There are a couple commands that will do this.
First *findmark:
https://2021.help.altair.com/2021/hwdesktop/hwd/topics/reference/hm/_findmark.htm
hm_createmark can also do this by using the "by node" option. Something like this:
*createmarkpanel nodes 1 (user selects node or some other method of picking node)
hm_createmark elems 1 "by node" [hm_getmark nodes 1]
set elemList [hm_getmark elems 1]
Hello,Jouher
Good evening
I think the following few lines of commands can help you.
set node_set [mdl_handle AddSelectionSet node] mdl_handle GetSelectionSetHandle node_select_handle $node_set node_select_handle Add "id $nodeid" set elems_set [mdl_handle AddSelectionSet element] mdl_handle GetSelectionSetHandle elems_select_handle $elems_set elems_select_handle Add "selectionset == [node_select_handle GetID]"
Just for your reference
