I used to change continuously between HM and HV within hyperworks. Some operations are meant to be run in HV whereas others in HM. So, i need the api to check which software is open to handle the errors accordingly
hi, you could check the client type, under the window handle.
If the window is set to FePre, it is HM. If it is set to Animation, it is HV.
Returns the window client type.
hwIWindow_handle GetClientType
