The Microsoft SQL Server 2000 driver for JDBC does not support connecting by using Windows NT authentication. You must set the authentication mode of your SQL Server to Mixed mode, which permits both Windows Authentication and SQL Server Authentication.
<operator name="DatabaseExampleSource" class="DatabaseExampleSource"> <parameter key="database_system" value="Microsoft SQL Server (Microsoft)"/> <parameter key="database_url" value="jdbc:sqlserver://MYSERVER;integratedSecurity=true"/> <parameter key="username" value="not_a_real_username"/> <parameter key="password" value="nkZ10Qek8Qw="/> <parameter key="query" value="select * from mytable"/></operator>
ratheesan wrote:Hi Keith,Where you mentioned the name of database such as master,northwind ...in this url "jdbc:sqlserver://MYSERVER;integratedSecurity=true"ThanksRatheesan
jdbc:sqlserver://MYSERVER;integratedSecurity=true;databaseName=mydatabase
keith wrote:I'm not certain why you're getting the error. A couple of things that might be affecting it are:1) Is your SQL Server install configured to user Windows authentication?2) Is sqljdbc_auth.dll in the Windows system directrory, or a directory listed in the PATH environment variable on the client?3) Are you connecting from a non-Windows client?Beyond those suggestions, you'll need to consult the Microsoft JDBC or SQL Server documentation.
