How to freeze the values after demagnetization and run back emf or SC test on the demganetised magnet
From the latest version of Flux there is a way to consider the demagnetization effect during the solving. When you create, your nonlinear magnet you select eh options:
Taking into acount the demagnetization effect during the solving.
Thanks.
attached a screen shot of the nonlinear magnet
Hi Akhila,
There is a way to reuse the magnet material after demagnetization.
I attached the document with the procedure to reuse the magnet material.
Thank you,
Lavanya
