I tried copying the data from the excel sheet to Tabled1 but unable to do it.
If you're using HM2020+ you will create the TABLED1 as a curve. You can use Ctrl+F and type 'TABLED1' for doing it quickly.
In HW2020.1 once you have the curve, go to 'edit' curve and then just copy and paste from excel. It is pretty simple.
Another option is to import from a txt or csv file. Just create a curve and add at least one point in the editor.
Then close it and go to the browser, and RMB in 'No of rows'
If you're using HW2020, then the only difference is that intead of copying and pasting all the values at once, you need to do it collumn by collumn, inside the editor.
