HI,
I have an hypermesh v19 installed and the problem is i have created geometry in SOLID EDGE and the geometry dimension i gave was 1000X1000 but when i convert it and import it to hypermesh the geometry is reduced can any one help
plase check the importing options in HM.
It is probably understanding that your model comes in inches and not mm.
Under the import options, you can provide the base units.
plase check the importing options in HM. It is probably understanding that your model comes in inches and not mm. Under the import options, you can provide the base units.
Thank you sir I will look into it.
