<operator name="Root" class="Process" expanded="yes"> <operator name="DirectoryIterator" class="DirectoryIterator" expanded="yes"> <parameter key="directory" value="/user/land"/> <parameter key="file_name_macro" value="fileName"/> <operator name="ExampleSource" class="ExampleSource"> <parameter key="attributes" value="%{fileName}"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="attribute_name_regex" value="label"/> <parameter key="condition_class" value="is_nominal"/> <parameter key="process_special_attributes" value="true"/> <operator name="NominalNumbers2Numerical" class="NominalNumbers2Numerical"> </operator> </operator> <operator name="LibSVMLearner" class="LibSVMLearner"> <parameter key="C" value="100.0"/> <parameter key="gamma" value="0.1"/> <parameter key="keep_example_set" value="true"/> <parameter key="svm_type" value="nu-SVR"/> </operator> <operator name="ModelWriter" class="ModelWriter"> <parameter key="model_file" value="/Users/land/Model%{a}.mod"/> </operator> </operator></operator>
