I need to crate a bead
Karshenas Reza
Altair Community Member
hi everyone. To optimise a complex system I need to create a bead in my geometry. From the properties of the bead are position, radios, length and Hight. I have to gain different results if I change each of these properties but the design should be so strong that I don't need to create neu geometry each time by changing the properties but geometry correct itself and.
I would be grateful for those tips
you could use Morph tools to create these, depending on how refined you need them. Are you familiar with it?
Another option is to use 'Replicate' tool to copy and create an existing feature of your model. It will copy and reconnect your feature into a new location.
