wallman prediction planes
bbch
bbch New Altair Community Member
Hey
I am trying to make a prediction plane along on of the walls in my model. I wanted to use the feature of wallman that should add a prediction plane on the side of the wall. I have an indoor database but when I select an object and go into object properties, I do not see any options under the “Miscellaneous” header. Dose anyone know why I am not able to do this.
I can make any arbitrary wall into a prediction plane.
  • MartinV_20771
    MartinV_20771 New Altair Community Member
    edited October 2019
    I think an object is either a wall or a prediction plane but not both. In the attached image, I added a new rectangle to an existing database in WallMan, selected it and edited its properties. The button 'Change Type' in the Properties window enables me to choose whether the object will be a regular wall with material properties or a prediction plane.
    If you want to see results on a particular wall of interest, you could create a prediction plane close to it, e.g. one or a few discretization 'pixels' away from it.
