I want design induction motor with skewed bar rotor, is there any axample to do that? Can i make it by skew or 3d?
Thanks
If you do the skew just for the rotor (stator) you can use the module skew of Flux. There are examples showing how to use the skew. One you open the Flux supervisor >> select Skew >> open example.
If you want to do the skew for both stator and rotor, in this case you need to use Flux 3D.
Best regards.
I will design it by drawing the motor not overlay , can i use the module skew?
thanks.
Yes you can use it.
Can i use any number for slices? For example just two slice.
Hi, Yes you can select the number of slices that you want.
Thank you.
you are welcome.
