Hi dears,
I am a master student, i made my project induction motor with altair flux 12.2 and after solving the torque is very low and appear this warning showing below
please your helping
thanks.
Hi Zainab,
You have a convergence error. Since the numeric method is not converging, reliability of your results (if any) is not guaranteed.
Please, check your inputs, your mesh and your simulation time steps, since these are the key factors that can affect convergence.
For further helps, additional information about the problem will be needed. In that case, you can post your project in order I can check it.
I also advise you to use last software version, i.e., Flux 2019.1. You will enjoy more functionalities that may be useful for your master thesis.
Best regards,
