I put the coating (3 mm) on a cube with working at the frequncey 18 GHz, and then Feko reminded me a error and warning.
Error 17063: Cube.Face15 - Coating LayeredDielectric1 on Cube.Face15 must be geometrically and electrically thin unless solved using physical optics (PO).
Warning 17064: Cube.Face13 - Coating LayeredDielectric1 on Cube.Face13 is not geometrically thin.
Thus, how to solve the problem and can Feko solve the coating problems?
Thanks.
