Finite Z component of E field for TE modes
User: "lostarmour"
Altair Community Member
Updated by lostarmour
Hi everyone,
I have been trying to simulate a waveguide junction problem with waveguide ports to calculate the field distribution on the aperture. I have a 5 circular waveguide problem where I use only TE modes at the small waveguide port. On the other end I have used a port with 0 excitation from all the modes to ensure an absorbing boundary condition.
The problem is that I still get a finite z component for the aperture E field. However, from theory we know that the aperture fields for a TE mode should have a 0 z component. This I have observed in only 1 waveguide problem too. This also happens when the discretization is lambda/25. Is that a numerical artifact? I am adding the cfx file also to this thread.
<?xml version="1.0" encoding="UTF-8"?>Screen Shot 2020-03-15 at 11.19.54 AM.png
1 - 4 of 41
    User: "Mel"
    Updated by Mel
    The waveguide is way overmoded. Even though you apply the TE mode, because of the dimensions many modes are propagating.
    From the OUT file:
      TE    1   1     4.55156E+09    3.98372E+02    0.00000E+00    0.00000E+00    2.77479E+02   Propagating
       TM    0   1     5.94492E+09    3.41078E+02    0.00000E+00    0.00000E+00    2.65650E+02   Propagating
       TE    2   1     7.55032E+09    4.47366E+02    0.00000E+00    0.00000E+00    2.47090E+02   Propagating
       TE    0   1     9.47229E+09    5.11613E+02    0.00000E+00    0.00000E+00    2.16061E+02   Propagating
       TM    1   1     9.47229E+09    2.77408E+02    0.00000E+00    0.00000E+00    2.16061E+02   Propagating
       TE    3   1     1.03857E+10    5.61795E+02    0.00000E+00    0.00000E+00    1.96761E+02   Propagating
       TM    2   1     1.26957E+10    1.58787E+02    0.00000E+00    0.00000E+00    1.23672E+02   Propagating
       TE    4   1     1.31454E+10    1.09505E+03    0.00000E+00    0.00000E+00    1.00945E+02   Propagating
       TE    1   2     1.31798E+10    1.11703E+03    0.00000E+00    0.00000E+00    9.89584E+01   Propagating
       TM    0   2     1.36461E+10    8.41727E+01    0.00000E+00    0.00000E+00    6.55583E+01   Propagating
    If the waveguide is made longer, at least the evanescent modes (again see OUT file) should have sufficiently died away over the length of the waveguide.
    User: "lostarmour"
    OP
    From the OUT file:
    Yes, I have all the other modes propagating as you mentioned. Therefore, I also tested when all these modes are active (excited) at the port and the result is different. And I even excited only the TM modes out of these modes and the result is again different. I have a theoretical model on MATLAB and I use z component for TE as 0 and for TM non-zero.
    My only TM mode simulation in FEKO matches the results of MATLAB (all modes excited). Therefore, I expected that the only TE mode excitation in FEKO should give me almost 0 z component of electric field.
    User: "Mel"
    Updated by Mel
    Your meshing should also be fine enough to avoid the warning:
    WARNING  4682: Coarse triangular mesh of a waveguide port for representing the field distribution of the modes included in the mode expansion
    User: "lostarmour"
    OP
    For example, take this example file I am attaching. In this I have excited only one TE mode at a frequency where the only TE mode is propagating. In this case also, in spite of having a mesh size of lambda/40, I still get some z component of E field. I guess because of this, when I add more modes, the z components due to only TE modes also get added.
    <?xml version="1.0" encoding="UTF-8"?>Screen Shot 2020-03-16 at 12.01.31 PM.png
