When I choose a near field source for far field computation, I am asked to choose a configuration with either one electric field source, both electric and magnetic field sources or magnetic field sources. What is the difference. For example, if I choose only electric field source, does it evaluate far field by a equivalent magnetic source (
\vec{M} = 2 (\vec{E}_{a} \times \hat z ) ) ? Or one needs to put an infinite ground plane surrounding it (so that the source becomes a slot) and then need to simulate?
