Sir,
here surface is not visible properly. i have checked the transparency, but everything is fine.
If 'everything is fine', where's your problem?
i mentioned about the geometry transparency. but i am not able to view the surface properly.
Try the transparency button see attached picture.
And be sure you are on shaded geometry not on wireframe.
Hi Sujith,
Looks like an issue with graphics. Update to the graphics card/drivers and try again.
Check for the compatible grahics cards for 14.0 before you update.
