Loads on Geometry
Punith
Punith Altair Community Member
Hello everyone,
is there any way to set the loads on the geometry permanently?. I mean after I set the load to surface and map them to elements, load is applied to all the elements belonging to that surface. But when I update the surface with new mesh the load crearted on the geometry before vanishes. Everytime when I create a new mesh I need to update the loads. Why cant hypermesh directly link the loads to surfaces rather mesh?.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited February 2017
    We apply loads & boundary condition on finite element model.Though we have some options which would help to apply loads on surface.So whenever you update mesh your loads should also update manually.
  • tinh
    tinh Altair Community Member
    Hello everyone,
    You should use HM14, after mapping a load, it is still existing on surf, so you don't need to update load
    actually you don't need to map loads, too. it will be mapped once you export mesh model
  • Punith
    Hello Rahul and Tinh,
    thank you so much for your replies.
    Punith Guptha
