Issue:
Error popup: 'There is no default server on which to submit the program'
This may occur if the 'Local' default server or the preferred server of choice setting has accidentally been changed.
Solution:
Locate the 'Server Explorer' view.
You need to highlight the Server in the list (there may only be one) that you would like to use as your default server to run SAS programs.
Right mouse click on this selected node and select the menu item 'Set as Default Server'.
You should no longer see the message 'There is no default server on which to submit the program'.
