How to Clear the temporary nodes? Find the following Image. It is not cleared even it I use the option ( Shift +F2) and it is showing in Post processing. Is there any other way to clear?
Hi Arul,
Please close all HyperWorks sessions and delete the below files from the Documents folder.
Hmmenu.set, hmsettings.tcl and command.cmf file.
Kindly confirm after deleting the files you are able to delete temp nodes.
Hi sir,
I can able to clear temp nodes after deleting .set .tcl and .cmf . But again it is showing temp nodes after importing the file. Is there any other way ?
This seems strange.
Clear the temp nodes and save as .hm file and try opening.
I will try and let you know.
Arul
hey arul, under geometry tab-temp nodes-select nodes and clear.
