Modal Correlation Error
Arul
Arul Altair Community Member
Hi ,
I am having following queries while trying Modal correlation option in Hyper view - NVH.
1. I am facing error while using transformation option in Hyper view - NVH - Modal correlation. Pls find the below image & help how to sort out.
2. How to use tolerance option in Node pairs menu. I could't able to get the values in the below table
Arul
  • Altair Forum User
    Altair Forum User
    edited September 2018
    Hi Arul,
    This error is shown because, you have not set the reference nodes properly. Please, go through the Help section to set the references properly.
    HyperWorks Desktop Applications > HyperView > NVH Menu > Model Correlation Utility:
     For eg: if you give Tolerance value as 100, it will select or display all the node pairs, which has a distance  less than or equal to 100.
  • Arul
    1.Could not able to sort out the error.
  • Altair Forum User
    Altair Forum User
    Hi Arul,
    <?xml version="1.0" encoding="UTF-8"?>image.png.c29ddb72c988115703fd765af6b244e5.png
    Now i see that you got different error (i.e. now the error shows for solid elements). Make sure you have set the references for solid elements too.
    Thank you
  • Arul
    The error shows for solid & Shell elements also. How to set the nodes? Is it required to select the same plane nodes for both models? or different plane for two models?
  • Altair Forum User
    Altair Forum User
    Hi Arul,
    Please can you share the related output files. Will check at our end and let you know how to proceed with it.
    Please use below FT link to share the files.
    https://ftin.india.altair.com:8443/filedrop/~osKE8Q
    Thank you
  • Arul
    Hi Premanand,
    Can I get tutorial with step by step for that??
    Arul
  • Altair Forum User
    Altair Forum User
    edited October 2020
    Hi @Arul
    Sorry for the late reply.
    Please refer below post and view materials shared by Rahul R. It covers video & pdf of model correlation.
    https://community.altair.com/community?id=community_question&sys_id=1d96807a1b2bd0908017dc61ec4bcb3c
    Thank you
  • Arul
    edited October 2018
    Thanks
