The macros enable the user to regroup the frequently used commands in an extension integrated into the software.
You can build up a macro instead of manually executing a series of repetitive actions in Flux, which you will then be able to call regularly.
A macro is interesting because it can encapsulate within a new command a series of repetitive operations and thus improve the quality and efficiency of the user-software interaction.
Concretely, a macro file (*.py) is a text file, which defines the macro-function in the PyFlux language. It receives (upon entry) one or more parameters and executes (upon exit) a series of predefined actions.
It is possible to use the macros provided with Flux or to create your own macros.
The list of macros provided with Flux is available in C:\Altair\Extensions\Macros.
