Workbench should not be prompting for a Kerberos username
Nico Chart_21517
Nico Chart_21517
edited September 2023 in Altair RapidMiner
The Kerberos authentication is (by default) the first authentication method in the list of valid methods from the workbench client to the SLC server. In the Workbench if you go to Window->Preferences->General->Network Connections->SSH2 and then visit the |Authentication Methods| tab you will normally see four methods: gssapi-with-mic, publickey, privatekey and keyboard-interactive. It is the first method gssapi-with-mic that is related to whether the Kerberos dialog forms appear or not. You can select the gsapi-with-mic and move it down to the end of the list if you wish the other methods to take precedence.
