In the workbench, STARTUP options are saved in the file <your_workspace_root>\.metadata\.plugins\com.wpc.wps\sessions.xml. For example:
<serverConnections default="Local">
<serverConnection autostart="true" initialDirectory="${workspace_loc}" name="Local" type="com.wpc.wps.connectionType.local" version="1.0">
<systemOption name="LINESIZE" value="132"/>
<systemOption name="PAGESIZE" value="39"/>
</serverConnection>
<serverConnection autostart="true" initialDirectory="${workspace_loc}" name="Local2" type="com.wpc.wps.connectionType.local" version="1.0"/>
</serverConnections>
Each server connection (such as 'Local') has its own list of user-defined STARTUP options such as PAGESIZE that will override the default value in <slc_install_root>\altairslc.cfg.
Customised STARTUP options are saved for each workspace/server combination.
