In FlowTracer and sometimes in NetworkComputer, you may encounter objects with SLEEPING status. These are usually colored black. This status indicates that there is a conflicting item in the flow, and you need to identify which of the conflicting items you wish to keep and remove the other.
The source of the SLEEPING status may be an output conflict, where more than one job in the flow writes to a given output file. The VOV system automatically detects these conflicts. Jobs will also be SLEEPING if you added items to a flow graph using the vovbuild command and a change was made to the environment or attributes of the job.
