Hi all,
Activate 2017.2 shows that it requires a Visual c++ compiler in spite of installing of the visual studio 2015.
Kindly inform the solution of the same.
Hi Arul,
Please look at topic Compiler required to use Modelica with Activate. The compiler you have chosen should be correct, please check if you have installed C/C++ option. Visual Studio doesn't install C++ by default.
Best Regards
