How to verify the different Altair license methods for SLC on Windows?
(A) Single Machine
e.g. Windows 11
MSI's to install: Workbench, SLC, and Altair Licensing.
1. SETINIT (wpskey) legacy license
Apply the setinit license. Check the file C:\ProgramData\altair\slc\5\setinit.dat is in place.
Select 'Local Server' > menu > Restart
Check 'Log for Local Server' window.
Time until 'Log for Local Server' subwindow refresh: <1s.
Remove (or rename) the setinit.dat file.
2. ALM local license manager
Run 'almutil -hostid' and send Ethernet hostid to Altair. Receive back a file (e.g. ALUS_ALUK_20241020_815143.dat.
Provide the file when prompted by the Altair Licensing installer.
Check 'Services' - Altair License Server is running.
In Workbench choose Help > Apply License, On-Premise Altair License
For the location use fqdn, hostname, localhost, or 127.0.0.1 or IP address.
SLC automatically restarts.
Check 'Log for Local Server' window shows the ALM address 6200@server... is being used.
Time until 'Log for Local Server' subwindow refresh ~2s.
Stop the service
3. Managed license
Arrange Managed license on AltairOne.
Choose Help > Apply License > Managed Altair License
Click 'New Authorisation'
Check 'Log for Local Server' window shows that 'Altair Managed Licensing' is being used.
Time until 'Log for Local Server' subwindow refresh ~4s.
(To disable use of Managed License I went to Local Server > Properties > Startup > System Options and I set ALMHHWU to FALSE.)
(B) Second Windows machine runs ALM.
On the other machine, check 'Services' - Altair License Server is running.
For the 'location' use 6200@server where server is replaced by the remove machine name - depending on your network you may need short hostname only, or fqdn, or IP address.
Time until 'Log for Local Server' subwindow refresh <1s.
