AUTHOR(S)
A. Janda, J.Y. Ooi
ABSTRACT
We present a numerical study on the DEM modeling of cohesive solids using a visco-elasto-plastic frictional adhesive contact model [1]. The capabilities of the contact model to capture the mechanical macroscopic behavior of cohesive materials were investigated by means of cone penetration and unconfined compression simulations. The results show that the simulations are able to reproduce qualitatively the typical trend of the penetration resistance profile in cohesive solid characterized by a steady-state at large penetration depths. The contact model is also capable of capturing the dependence of the penetration resistance on the consolidation stress history. Furthermore, the simulations reproduce the relationship between the unconfined strength and the penetration resistance that has been reported in real cohesive materials. Finally, we investigated the scaling laws of the contact model parameters to produce the same load–deformation behavior invariant of the particle size used in the simulations. The results demonstrate the suitability of the proposed model to simulate complex processes involving cohesive solid at large engineering scale scenarios.
KEYWORDS
Cohesive solids Cone penetration, Discrete element method, Parameter scaling, Unconfined strength
