AUTHOR(S)
H. Zuo, J. Wang, Q. Xue, X. She, Z. Dong
ABSTRACT
Ironmaking using an oxygen blast furnace is an attractive approach for reducing energy consumption in the iron and steel industry. This paper presents a numerical study of gas–solid flow in an oxygen blast furnace by coupling the discrete element method with computational fluid dynamics. The model reliability was verified by previous experimental results. The influences of particle diameter, shaft tuyere size, and specific ratio (X) of shaft-injected gas (SIG) flowrate to total gas flowrate on the SIG penetration behavior and pressure field in the furnace were investigated.The results showed that gas penetration capacity in the furnace gradually decreased as the particle diameter decreased from 100 to 40 mm. Decreasing particle diameter and increasing shaft tuyere size both slightly increased the SIG concentration near the furnace wall but decreased it at the furnace center. The value of X has a significant impact on the SIG distribution. According to the pressure fields obtained under different conditions, the key factor affecting SIG penetration depth is the pressure difference between the upper and lower levels of the shaft tuyere. If the pressure difference is small, the SIG can easily penetrate to the furnace center.
KEYWORDS
Computational fluid dynamics, Gas–solid flow, oxygen blast furnace, pressure field, shaft gas injection
