AUTHOR(S)
J. Horabik, M. Molenda, P. Parafiniuk
SOURCE
Physica A: Statistical Mechanics and its Applications
ABSTRACT
We use numerical simulations based on the discrete element method (DEM) to study the response of a cuboidal assembly of spherical (diameter d) or spheroidal particles to uniaxial compression. This study examines the influences of slight deviations from the spherical shape of particles or of the thickness of cuboidal samples on the packing and mechanical characteristics of the assembly. The spheroidal particles were fabricated by the multisphere method. Eight different particle shapes were considered, each with the same volume and with aspect ratios α from 1.0 to 2.5. The final vertical height and larger horizontal depth of the cuboidal deposit were 15d, whereas the thickness ranged from 1.025d to 10d. Upon increasing the assembly thickness or deviating from a spherical shape, numerical examinations by the DEM revealed clear differences in the packing structure and uniaxial compression of assemblies of spheroidal particles. The departure from a spherical shape results in intense changes in contact network, which is manifested as changes in the volume fraction, mean number of contacts per particle, and ordering of the deposits. For the more elongated particles, the pressure ratio as a function of spheroid aspect ratio reached nearly constant values regardless of the sample thickness.
KEYWORDS
2D–3D transition, Discrete element method, Granular Mechanics, Prolate spheroids, Uniaxial compression
