AUTHOR(S)
J. Wiącek, M. Molenda
SOURCE
International Journal of Solids and Structures
ABSTRACT
The role of particle size heterogeneity on micro- and macromechanical properties of assemblies of spherical particles was studied using DEM simulations. The response to an imposed load of a granular material composed of non-uniformly sized spheres subjected to uniaxial confined compression was investigated. A range of geometrical and micro-mechanical properties of granular packings (e.g., void fraction, contact force distribution, average coordination number and degree of mobilization of friction at contacts between particles) were examined, and provided a more accurate interpretation of the macroscopic behaviour of mixtures than has previously been available. The macromechanical study included stress transmission, stiffness and angle of internal friction of the granular assemblies. The degree of polydispersity showed slight effect on both, the void fraction and the elastic properties of the system. The tendency for increase in the lateral-to-vertical pressure ratios was observed with an increasing degree of particle size heterogeneity; however, the different pressure ratios calculated for samples with various degrees of polydispersity lay within the range of data scatter.
KEYWORDS
Discrete element method, Granular media, Macromechanics, Micro mechanics, Particle polydispersity
