AUTHOR(S)
D. Blackwood, J. Kresevic, M. P. Mullarney, W. R. Ketterhangen
ABSTRACT
In the production of pharmaceutical tablets and capsules, a lubricant such as magnesium stearate is often added to the powder blend or granulation in order to reduce friction and, in some cases, minimize sticking to the manufacturing equipment surfaces. If the lubricated blend is exposed to excessive shear during the processing steps prior to tableting or encapsulation, adverse effects on quality attributes of the final dosage form may be observed. These could include an increase in wetting contact angle, a slowdown in disintegration and/or dissolution, and a reduction in the tensile strength of compacts.In this work, two different computational modeling approaches are proposed to predict the effect of shear during the processing of lubricated pharmaceutical blends on drug product quality attributes. In this case study, an agitated powder feed system is examined, but the approach could be readily extended to other powder processing operations. First, a framework for the prediction of lubrication-based tensile strength reduction using the discrete element method (DEM) is proposed. This approach utilizes a companion study in a lab-scale, high-shear mixer to map the DEM predictions of extent of shear to an experimentally relevant tensile strength prediction. Second, a compartment model (CM) approach is proposed to model the powder flow and lubrication in the feed system. The tensile strength predictions from these two different approaches both compare favorably to experimental measurements of tensile strength.
KEYWORDS
Compartment model, Discrete element method, Encapsulation, lubrication, powder feeding, Tensile strength
