AUTHOR(S)
C. Hang, R. Zhu, Y. Huang
SOURCE
Journal of Terramechanics
ABSTRACT
The identification of the movement behaviour of soil in the area under the combined effect of two subsoilers (i.e., the area between two subsoilers) is one of the key issues in determining a reasonable inter-subsoiling shovel distance. The present study established a working model of subsoiling using the discrete element method (DEM). Based on this model and an indoor soil-bin experiment, the present study focused on investigating the micro-movement and macro-disturbed behaviour of soil in the area under the combined effect of two subsoilers. The results show the following.(1) The range of transverse and longitudinal disturbance of soil decreased with increasing distance between the soil and subsoiler. The range of disturbance of the soil in the shallow layer was the widest, followed by the range of disturbance of the soil in the middle layer and the range of disturbance of the soil in the deep layer. The simulated and experimental values of the mean displacement of the soil in the shallow layer (tracer blocks with a side length of 10 mm) were 34.81 mm and 34.55 mm, respectively (error: 0.75%).(2) The force on the soil particles in the deep layer was the greatest, followed by the force on the soil particles in the middle layer and the force on the soil particles in the shallow layer. The force on and the velocity of movement of the soil particles at different locations decreased with increasing distance between the soil and subsoiler.(3) The discrete element simulation could accurately simulate the disturbance process of the soil subjected to subsoiling. The sectional profiles of the disturbed soil obtained from the simulation and experiment were consistent with each other. The relative error between the simulated and experimental values of the soil looseness and the soil disturbance coefficient was 14.45% and 12.06%, respectively. Based on the DEM combined with an indoor soil-bin experiment, the present study determined the movement behaviour of the soil in the area under the combined effect of two subsoilers. The results of the present study can facilitate in-depth investigations of the subsoiling shovel–soil interaction and provide a basis for making decisions to optimise subsoiler arrangements.
KEYWORDS
Combined effect of two subsoilers, Movement behaviour of soil, Subsoiling
