As SimSolid 2021.0 has the batch run feature with Java script, HyperStudy DOE can be applied with this feature.
https://community.altair.com/community?id=kb_article&sys_id=4366b70edb1cb014e8863978f496195c
This sample shows the parametric study of Width, Length, and Height with the following geometry and extract the eigen frequency of #7 from unv.
The following files are found in the attached zip.
The Study_1.hstudy setup is shown below:
1. The modal.tpl is created from java script as below:
The parameters and the file names are associated.
Please change the folder path appropriately.
2. Solver Execution Script needs to be registered.
3. The modal.bat is below:
"C:\Program Files\SimSolid\2021\SimSolid2021\Simsolid.exe" -s modal.js -l log.txt
Input variables:
Run Definition
The eigen frequency of #7 is extracted from unv:
Proceed to DOE and set Run Matrix at Specifications:
run_matrix.csv is shown below:
1,2,3
100,50,1
110,50,1
100,60,1
100,50,2
Eigen frequencies of #7 are extracted.
