🎉Community Raffle - Win $25
Join and Win
How to fix EDEMpy script Error?
User: "Salma Hassan"
Altair Community Member
Updated by Salma Hassan
I’m running a Python script for the Static angle of the repose test, but it showed a ”Type error: ‘float’ object cannot be interpreted as an integer” as attached.
I didn’t change the script, I just follow the guide PDF file to run EDEMpy,
would you please help with this?
Thank you
Regards
1 - 1 of 11
    User: "Stephen Cole"
    Updated by Stephen Cole
    Hi Salma,
    I believe you are using an older version of the script.  You can find the latest version installed with EDEM, you can copy it from your install location.
    Default location (on windows) is:
    C:\Program Files\Altair\2021.1\EDEM2021.1\examples\Calibration Kits\Static angle of repose test
    Regards
    Stephen
