The aim of this document is to show how to create and use tabulated parameter in Flux to impose real waveform for the supply in a transient magnetic application, for example, to check how losses are impacted when we used current with Harmonics.
In the presentation, two ways of importing will be described:
1) directly by copy-pasting the data from a spreadsheet
2) by importing of a .txt file containing values for the time and current.
Finally we will see how we can make the signal imported periodic to simulate more than one period.
