I am opening results for a file having both 1d beam elements as well as rigid elements and both are getting shown as a single component. How to make them into two separate components as they are in the hypermesh file.
Normally while modelling we keep beams & rigids in separate collector.Because beam need property & rigid dont need any property.
So in your case if both are in one collector then have control on element via mask : element by config option.In Hv we dont have mask browser like HM to have control.
Also check with Preferences pulldown:option for visualization. See attached screenshot.
Hi Gopal,
Can you try with loading the model file in load model option (_0000.rad file for radioss) and load the .h3d file in load results file option of HyperView, so that all the component collectors will be loaded as in HyperMesh.
Hi George and rahul,
I have followed the above steps and it is working .
Thank you
