Motion on Joints with MOTNJG
1.MOTNJG Basic Parameter
Format
Where,
Field
Contents
ID
Motion set identification number.
(Integer > 0)
JIDi
Identification number of a JOINTG Bulk Data Entry on which the motion is to be applied.
DOF
Degree of freedom component number.
No default (1 ≤ Integer ≤ 6)
VALUE
Real
Motion value to be applied on the identified degree of freedom for the specified JOINTG joint. For more information, see the corresponding joint description on the JOINTG entry.
FIXED
The corresponding degrees of freedom of the JOINTG entry are fixed.
No default
2.Creating MOTNJG
3. Loadstep
