If you encounter graphic problems in Flux software while displaying colour shades for instance, you should check if the drivers of your graphic card are up-to-date. In order to do that, you have to execute the following procedure:
| 1 | From Start, type dxdiag in the Search zone and then click on dxdiag.exe
| 2 | In the displayed Diagnostic DirectX tool window go in the tab Display in order to see the characteristics of the graphic card and the drivers. What you have to check is the date of the last drivers update. Then you can check on internet if there are newer versions of these drivers.
| 3 | Click on Save all information in order to save the information of your PC configuration in txt file. If needed you can send this txt file to the support.
