Reset Login Password In Automator
Updated by Rebecca_Cronin
Have you found yourself needing to Reset your Login Password In Automator?
Problem:
Unable to login or password is incorrect
Solution:
Here are the steps on how to reset default login
- Open Run Configurator
- Go to Configurator Tab then Instances
- Click Database Operations
- Click System Admin Unlocker on the lower side of the window
- Click Refresh so the Username will show up
- Check on Reset password, Attempts count and Reset attempts, and click submit
- Try to login again using the default credentials (admin/password)
- If you are still running into trouble please do not hesitate to contact our Support Team at: DASupport@altair.com
See Also:
Reset Login-Password in Automator
Comments
No comments on this post.
