🎉Community Raffle - Win $25
Join and Win
Run Distributed StarRC (NetworkComputer)
User: "Goetz Leonhardt"
New Altair Community Member
Updated by Goetz Leonhardt
Newer versions of StarRC support distributing the load to various machines. The following configuration will work with NC on the backend:
setenv STARRC_DP_STRING "nc run -ep "
If you have issues with your configuration, start with this basic setup.
Then add jobclass statements and other flags.
If you encounter a specific issue after that, contact customer support.
Comments
No comments on this post.
