Dear Sir,
currently i am working in CFD analysis of the valves and i am undergoing the error as ( Can't orient elem piece-1) while following the steps in tutorial
CFD-1100: Creating a Hybrid Grid with Varying Boundary Layer Thickness
As my model contains small distance between the opposite walls (i,e 0.1mm) i need to generate a distributed thickness distribution to prevent boundary layer interference /collision in zones where the distance between opposing walls is too small to accommodate the baseline or nominal boundary layer thickness.
Kindly provide your guidelines
Thanks
RAM
