How can I create NdFeBo magnet in Flux starting from supplier data?
Yann_Le_Floch
Yann_Le_Floch
edited November 2021 in Altair HyperWorks
You have to take care about the fact that supplier are giving J(H) curve and B(H) curve. In Flux, only the B(H) curve should be entered. It means for instance that at room temperature, the B(H) curve will be defined with a linear model in Flux using Br and µr values.
