The scalar values of I/O parameters can be written in a txt file as follows:
| 1 | Collect the values of the I/O parameters. To collect for instance two I/O parameters in a table, you can proceed as follows: values= [ScalarResult['CurrentValueInOutParameter_1'].value, ScalarResult['CurrentValueInOutParameter_2'].value ]
| 2 | Write the parameter values in a file. You can use the following command lines: f=open('test.txt','w') for i in values: f.write(str(i)) f.close()
