In HyperMesh we use the Element Quality view to review the element quality.
To enable the Element Quality view, click
on the View Controls toolbar and select Element Quality.
If you want to check the time step for the model of an explicit analysis, you need a criteria file in which the time step criterion has been defined.
To add the time step criteria you can right-click on the legend and select Edit Criteria.
Or make the setting beforehand via Topology / Criteria and define the Time step criteria.
